Have you tried
Posted by: AudiSport4000 (98) on 2017-10-13 00:07:21
In Reply to: Fuel injector o-ring and seat replacement posted by dreamcardriver on 2017-10-13 00:01:33
Have you found any metric wrenches that do fit over both the fuel line and injector itself? If it is too bad and you can sort of get a wrench on each, then squeeze with your hand to break it loose. I had to do this with the fuel accumulator lines.
They will come off :) I assume the lines are totally off the car? If not, maybe try that as you may have more leverage on a bench.
