"Velox, Versutus, Vigilans"
1993 90CS
1995 90Q
MODS/MAINTENANCE:
1995 90 Sport Quattro
MP3 JVC Head Unit. 40W 5 1/4"s In Back. 40W Pyramid "Royal Blue" 4"In Front.
JL Audio 15W3-D2. Kicker 40X2 Amp (Bridged To Mono, 80X1) Kicker 40X4 Amp. Two 1 Farad Caps.
trip computer and chrome rings in main cluster
RS2 Headlights/H.I.D. 4300K,Silvanya Silverstar H1 For High Beam.
Headlight Adjuster Motors (VW).
Aux Gauges
Seima OEM Tinted (Euro) Tail Lights, Custom Painted Inner Tail Lights.
Jacquard - Sport cloth Upholstery.
restored stock fog lights
Audi "sport" springs
Bilstein Sport Struts, B5 A4 Rears.
Tie Rod Ends. Ball Joints.
Control Arm Bushings.
Canadian DRL Light Delete.
Fog Light Relay Mod (Fogs On Without Low's).
2 Air Fuel Meters(1 per O2 sensor).
Ported & Polished Intake Manifold.
Gasket Matched Heads.
Mance XTB+, Velocity stack, HVRS, Pro Mounts,Snub Mount & sway Bar Links
Bored Out MAF Sensor (3")
3" Silicone Intake
2002 Allroad Transmission Mounts
Super leaky exhaust.
1993 90s ( sold :( )
MP3 JVC Head Unit
Change holder from a 1990 100.
Retrofitted B3 Aux Gauges and ashtray.
Replaced stock cloth with leather (panels and seats)
Brembo drilled rotors. PBR Pads
034 Motorsports Strut Mounts, Density Line.
Bilstein HD Struts.
Tie Rod Ends. Sway Bar Links. Ball Joints
Front Wheel Bearings. control Arm bushings
Custom Exhaust(1 CAT and stock mid mufflers removed..sounds garbage form 2900-3200RPM)
Fog Light Relay Mod (fogs on without Low's)
New Injectors/fuel rail FPR (2002)
S&B Cone Filter
