quattroworld.com Forums: Do you know where the tach gets it's signal from?
All messages | Search Forums | Return to 80/90 Coupe + Cabriolet
Posted by: kodaS6 (19367) on 2016-12-07 11:38:31
In Reply to: Tach pick up and Temp sensor will go first before the gauges themselves. Check them first. posted by JunkerAvant on 2016-12-07 08:18:45
I don't have a bentley for the 90 but do have Alldata which has been somewhat helpful but definitely not as good as the bentley. I should be able to check the wire for voltage ( once I find the correct one) and try to eliminate if it's the instrument cluster or not.
